Hi!
i'm intresting what resources (GPU/CPU) resolume use for dmx perfomance? Sometimes when working with dmx on my mbp 2015, my cpu goes to 100% load, then drop fps from 60 to 20 for a second and start working fine. It happenes with generative sources (lines) and prerendered sequences.
DMX performance
Re: DMX performance
DMX output is not very heavy, if you play many layers to create the pixel data for it, that can be.
Is this a macbook with dedicated graphics?
Does mouse movement or scrolling in other apps like google chrome lag too?
Re: DMX performance
Have you checked which app uses the 100% cpu in the Activity monitor?
Re: DMX performance
it is kernel_task. i think that dmx sequences work with cpu perfomance (cause it work with tables) and thats why get overheat and kernel_task drop processes to cool down CPU.
Re: DMX performance
And because macbooks are very poorly designed to handle thermal load4omp wrote: Wed Nov 07, 2018 16:03 thats why get overheat and kernel_task drop processes to cool down CPU.
Could you send us your composition and the advanced output preset you use?
