Resolume 6 Personality for AVOLITES
MichaelManlapaz
Post by MichaelManlapaz »
I am trying to use Arena for Avolites but they only have properties for Reolume 5 and 4.
Any luck on releasing properties for Resolume 6.
Re: Resolume 6 Personality for AVOLITES
I guess you should ask Avolites about that.
​Resolume Arena 6 doesn't have the DMX auto map, you might be using with Arena 5.
That also means there is no fixed channel layout now.
The upside is that, with the re-designed shortcut system in Resolume 6, you can create your own DMX shortcut profile in about 30 minutes that fits exactly your workflow.
Have a look at our support page if you need more information on this here: https://resolume.com/support/en/dmx-sho ... map-preset
until you get something custom from them, have a look at this shortcut preset which should allow you to work with the Arena 5 personality.
viewtopic.php?f=12&t=16077&hilit=DMX+automap
You can copy the preset there to the Documents/Resolume Arena 6/Shortcuts/DMX folder, restart Resolume, an load it in the Shortcuts panel as DMX preset.
