Hey guys. Is anyone else experiencing an issue where Resolume 6 is only pulling low end in the FFT audio input? I have tried every combination of gain and audio settings with no luck. I also took Resolume 5 and 6 side by side and I get the full audio range in 5 but not 6. See video here.
https://photos.app.goo.gl/CM6dXjJbXMLQy ... 1TuvBCff5s
Using Resolume 6.1.1
Resolume 6 FFT Audio Only Has Low End
AdevProjects
Re: Resolume 6 FFT Audio Only Has Low End
Is this is on the same computer?
It looks like it is the same signal but just a different gain level for V5. I can confirm that on the same computer using the same audio input, with the same default audio settings, the level in V5 in the fft monitor appears to be louder.
Not sure if this just the visual monitor only or it is at a higher gain level.
See screenshot - Top is V5, Bottom is V6:
Same computer, same settings throughout, and the same exact audio source. Res 6 is hiking the low end on the FFT input. I've even tried playing high screech noises and they register in the low end of the spectrum and nothing registers in the high end. Makes it impossible to capture the high end or mid range sounds ina
song. Also makes it impossible to capture clean low end because RES6 is blending the low and high end all together. Never had this issue in RES5.
