Hello,
project in advanced output with 2 FX4 2160p50 in displayport, 1 1080p50 for control and 1 108050i to feed a blackmagic Mini recorder.
I have a clip (6736x1217 comp) running smoothly.
Sometimes it starts to stutter and the strange thing is that if I open the advanced output window it runs smooth again.
I set up comp to 50fps and I have Vsync (GTX1080) disabled.
Another thing is that if I enable Vsync even if I have 50fps on comp, output is at 25fps (I think this is due to 108050i output).
Any suggestion?
Thank you
Stefano
						Stutters on Advanced output
Re: Stutters on Advanced output
I reply to myself…
Switching the 108050i output to 1080p25 solved the problem.
Stefano
Stefano
I think it can help me combine the 2x cube from the GTX 1080 brand graphics card, but can you help me with the stuttering problem?
