Ableton Audio to Arena
Marvel Feranti
Post by Marvel Feranti »
Is there anyone who can help me set up an audio out from ableton directly in to Arena (both applications run on the same MAC) so i don't have to use the microphone on the laptop. I want to put the audio out as well but being able to adjust the volume out separately from the input audio level. I have an external USB soundcard (Scarlet Focusrite) so maybe it can be of any use for this purpose.
any help will be much appreciated!
Nils
thedawjones
Re: Ableton Audio to Arena
Post by thedawjones »
This should work.
http://jackaudio.org/
Good luck.
djrummer
Post by djrummer »
If you're willing to spend some money, the iConnectivity audio interfaces have routing to allow for that in the interface, as opposed to using a 3rd party software (which also works!)
Marvel Feranti
Thank you all, i'll check it out :D
