Hey.
What about soft loop option?
Fade individual clip’s next loop to avoid jumping
When loop is not perfect.
Ha, and please don’t advice to duplicate clip and autopilot between. This is wrong.
						Soft loop
Re: Soft loop
Ask Joris for feature request #1693
Best wishes
 Best wishes
 Do you like outlines? Easy Outliner on Juicebar
 Do you like outlines? Easy Outliner on Juicebar Re: Soft loop
What about Envelope / Oppacity / Animate Timeline
Do your own softloop if you want one...
Laptop: XMG P507 // Intel i7-5500 / GTX-1060 / 1tb SSD / 32gb RAM //  Lemur / BirdDog Studio NDI
~Berlin~
~Berlin~
- Bassindaniel
Re: Soft loop
Not a real solution.He2neg wrote: Sun Dec 02, 2018 13:04 What about Envelope / Oppacity / Animate Timeline
Clip will not fade with itself.
- Bassindaniel
Re: Soft loop
Sure can you blend the Video inside itselfe..why shouldnt it be possible...
Clip -> loop
Opaccity -> Clip Position -> Envelope -> Set the keyframes you need
All Fade in / out are possible at the beginning and at the end of the clip
#delete 1693
									Clip -> loop
#delete 1693
~Berlin~
~Berlin~
- Bassindaniel
Re: Soft loop
In this case the “loop” will be fade to black and fade in.
Again. not a solution.
Re: Soft loop
Ok, you "only" can fade to 50% then jump to the start at 50% and continue... but when you want to mix 2 things (even when they are the same) you need this thing 2 times...
you must copy the clip and fade from 1 instance to another. but you dont want to do that as well...
so yes i see you have a problem, but it aint mine... so enjoy having it.
~Berlin~
~Berlin~
Re: Soft loop
Well, technically you can hack your way around.
The key is to offset the animation so you can crossfade between this one in and out so the perfect effect for this is Delay RGB with all 3 sliders full on. Then just crossfade the effect at the beginning and end (but dont fade out to 0% otherwise it will bypass the effect). So set the lower values to 0.01%. The effect's opacity playhead/envelope should be set to clip and you are good to go.
In my example I just trimmed my animation to make it 'unloopable' but you can see that this way you can pretty much loop anything which is not loopable with this effect. The only problem is that the delay RGB might not be 'late' enough but oh well, it works
