Text Animator Countdowns
AdevProjects
Post by AdevProjects »
I spent a bunch of time playing with the text animator and shaper effects to make some countdown timers and some animation.
Heres what I came up with:
Also Attached Composition:
Layer 4: 5 Min countdown timer starting at first clip. Flashes red every 1 minute.
Layer 3: 25s Countdown Timer with in and out animations, starting from first clip.
Countdown Timers.avc
(562.91 KiB) Downloaded 716 times
I had problems keeping multiple timeline clips in sync and so for each timer there is only 1 clip active at once so only 1 timeline is running at once.
Could be good as a way of doing a NYE countdown using resolume only for the last XX seconds.
juicewon
Re: Text Animator Countdowns
Post by juicewon »
Clever.
Thanks for sharing.
5950x 3090 FE 128gb DDR4 2tb NVME X3
M1 Max MacBook Pro 64gb 2tb NVME
RazerBlade 16 4080 32gb DDR5 4tb NVME
