Decklink 8k pro outputs
willtom
Post by willtom » Wed Dec 12, 2018 11:57
After a bit of advice. In the resolume manual it says:
Blackmagic SDI outputs always require an external hardware reference clock to stay sync.
Is that only when using more than one card? Do all the sdi outputs on a single decklink always stay in sync with each other regardless of external sync, or is every sdi output completely independent of the others as far as sync is concerned?
willtom
Re: Decklink 8k pro outputs
Post by willtom » Wed Dec 12, 2018 12:11
Arvol has previously answered this here
viewtopic.php?t=17288
The outputs of a single decklink are not synced with each other
