dxv3 codec content can't be imported into AE CC2019
vincent.
Post by vincent. » Thu Dec 13, 2018 17:30
I just used OSX Mojave's new screenshot app to record one of my displays. The resulting video clip can't be imported into my AE project; it cames that the DXV3 file is 'damaged or unsupported'.
What can I do about this? I've already tried reinstalling the codec which didn't work. Is there a way for me to uninstall it? Would that fix the problem. For some reason my machine is exporting that captured video using the dxv3 codec.
I'm on a macbook pro 2017 edition with the most up to date version of osx.
Re: dxv3 codec content can't be imported into AE CC2019
Post by Arvol » Thu Dec 13, 2018 19:37
So the screenshot app encoded the video in DXV3? Can you try having it use a different codec and see if that works?
Maybe capture it in a different codec, do your editing in AE then export from AE into DXV3.
francoe
Post by francoe » Thu Dec 13, 2018 20:32
Strange, the mojave's screenshot app can only encode to h264 (not customizable). More strange, you can encode dxv3 just using alley, adobe plugins or old qtkit components. Maybe I'm wrong, but I suspect non of them can be called from avfoundation.
Vincent, are you sure capture was made by screenshot app?
In the other hand, Adobe exporter plugins allow AE cc2019 to read dxv3 files? :roll:
Post by Joris » Thu Dec 13, 2018 21:42
OSX's screenshot app definitely encodes to h264.
There is however what we think might be a bug in Adobe's importer framework. When importing a file, we we try to look if a file is a DXV encoded file. If not, we give it to Adobe to handle, but Adobe will then keep *calling it* a DXV3 file, even though it's not and it's doing all the loading and decoding itself. It's like meeting someone and asking if their name is Bob, they say no and introduce themselves but you keep on calling them Bob anyway. It's not really harmful, but it leads to all sorts of confusing situations.
So what I think happened was that OP somehow got a corrupted h264 recording, tried to open it in Adobe, and Adobe said the "DXV3 file" he tried to load was unsupported. Leading to the confusion we now find ourselves in.
We'll be happy to take a look at the file if you like, but I'm 99% sure this is what happened.
Post by Joris » Thu Dec 13, 2018 21:49
You can remove the Adobe DXV plugins by deleting them from
/Library/Application Support/Adobe/Common/Plug-ins/7.0/MediaCore/Resolume DXV
and/or
/Applications/Adobe After Effects [version]/Plug-ins/Resolume DXV
