Remotely controlling Arena
moha20106
Post by moha20106 » Thu Dec 20, 2018 20:36
Hi all,
I'm asking for the way to remotely controlling the Resolume Arena
My PC will be behind the led display for the connections to the video-proseccors
But the control area and the operators will be far and in the different place
So, I'm asking about the way to controlling the Arena software remotely by laptop over UTP cable
Or any idea to remote it
Anyone have idea about that?
Re: Remotely controlling Arena
Post by Oaktown » Fri Dec 21, 2018 00:14
Any VNC program will do that for you so that will be no problems.
I've personally programmed, mapped, and maintained Arena 6 projects from thousand miles away many times. Actually, I was just in New York working on a show in San Francisco that I programmed in Arena 6 using Chrome Remote Desktop!!
Post by Arvol » Fri Dec 21, 2018 03:34
Teamviewer is what I use to connect to my remote servers.
If you're in the same building. You may look into OSC
moha20106
Post by moha20106 » Fri Dec 21, 2018 08:53
I may haven't internet to control it by Chrome remote
I'm asking if Arena support remotely control like hippotizer before i use
SystemD
Post by SystemD » Fri Dec 21, 2018 09:51
Personnaly, I use 2 methods :
- tightVNC On Arena's PC and Chicken_of_the_VNC on my Mac for the remote
https://www.techrepublic.com/article/ho ... te-access/
https://en.wikipedia.org/wiki/Chicken_of_the_VNC
- Or OSC communication between Arena's PC and another computer with a Max patch
https://cycling74.com/
Post by Arvol » Fri Dec 21, 2018 18:24
OSC is what you're after
Empyfree
Post by Empyfree » Fri Dec 21, 2018 21:03
Or artnet if you’ve got a lighting desk handy!
moha20106
Post by moha20106 » Fri Dec 21, 2018 23:43
Excuse me, i don't know what is the OSC
can you explain what is this please?
Post by Arvol » Sat Dec 22, 2018 00:13
https://resolume.com/support/en/osc
A Very Flexible way to control anything. Can also be triggered via cellphone ;)
moha20106
Post by moha20106 » Sat Dec 22, 2018 02:34
Thanks Arvol for your reply
