numbers in corner out output window???
ZooPH
Post by ZooPH »
hiya reolumers...
Just wondering what those numbers are that are outputed in the corner of the fullscreen window output? Some kind of performance indicator? How do i get rid of these?
great new version! :)
thanx,
paul
edwin
Post by edwin »
did you press ctrl+alt+i ?
if you did then these numbers show up..
press ctrl+alt+i again to hide them
Edwin
pifco
interesting
Post by pifco »
What are they for? framerate or something?
continuity-B
Post by continuity-B »
yup
ZooPH
Post by ZooPH »
strange... actually i still cant get rid of those corner numbers or frame rates. If i press ctrl+alt+i another layer of info comes up regarding resolution settings and effects applied etc. The other numbers (in yellow) remain there, the other info(in red) disapears on pressing ctrl+alt+i again.
whats the score? can i get rid of these numbers?
thanx for an awesome program, the new flash integration is fantastic. The possibilties of resolume with flash8 will be incredible.
kilops
Post by kilops »
If the number yellow, Make sure you dont have a software like FRAPS runing...
This software is for video capture (for 3D), but it also overlay a frame rate counter on all DirectX rendered screens.
cat
Post by cat »
If they're yellow and your running omega drivers, turn off the fps option in the dx prefs
ZooPH
Post by ZooPH »
thanx cat....
cant seem to find the settings you mention, could you please provide a little more info?
ZooPH
Post by ZooPH »
if anyone can help me with getting rid of these numbers and directing me to the "fps option in the dx prefs " i would be mightly greatful as i have a gig in 2 days time and need to banish the blighters!! :)
Anonymous
Post by Anonymous »
dunno if you already found it. i had the same problem....
you have to make a rightclick on the ati tray tools -> tools and options -> osd
and then check the option box "hide" at fps meter...
