Decklink Outputs Master Fader screens go white
sage12
Post by sage12 »
How does water get splashed when washing dishes?
It is a nuisance for any housewife to witness her kitchen being splashed with water after every washing of the dishes. Be sure that around your "territory" always have a few towels to clean.
Having a new house, women often take care of their investment in kitchen space so that it is the most modern and convenient: from the style, style, material of kitchen cabinets, sinks, ... Go to the dishwasher. But it is not expensive to wash the faucet, it will not cause problems for you when washing dishes. Because these things only arise when you actually use them.
I have a sister who has invested in the kitchen, it is very glittery. For a while she shook her head:
- I see the consulting shop should not buy soft wash hose (hose combined with short lotus wire) because after a while this type of water often leaked, so I decided to choose a hard bowl wash hose. It is true that my kitchen is more luxurious.
I studied and then asked:
- "You don't need to adjust" so you shook your head?
She is witty:
- Well "hard" is "hard" but "curvy" so I can't manage so the water is splashing every time I wash the dishes.
After a period of use, the residue of water such as CaCO3 together with other contaminants settles into the latch slots of the washing hose, making it difficult to turn and rotate. Sometimes the design of the washbasin is hard to fold so that the operating radius of the water flow is narrow, making it very difficult for the users to clean the sink. Large items such as trays, baskets, large discs that need to be washed directly under the tap will be very difficult. That is the main cause of water splashing when washing dishes.
See more at: http://learncookingus.com/spotlight-on- ... -plumbing/
I patted your sister's shoulder:
- God, what do you think? I have a solution to "tap" her home!
What is the smart solution, outstanding savings for your kitchen space?
1. Intelligence:
Overcoming the disadvantages of most of the hardened dishwashers mentioned above, SENZINY has researched and launched the product line: 360-degree SINGLE HEAD. The 360-degree smart design of the product will make your "stubborn" dishwasher faucet flexible, the water can go to every corner of the sink without losing the inherent elegance of the product. Products.
2. Saving:
Instead of having to spend millions, even tens of millions of dongs, installing a new washing hose for your kitchen, just one
is that you can easily select and "show" yourself 360 degree nozzle products that synchronize with your home faucet. With a really reasonable price, the consultant of SENZINY definitely does not disappoint your family.
3. Outstanding:
Is a smart product, 360 degree nozzle also integrates color changing leds without electricity. Not only does it fix water splashes, 360 degree probes can help you feel the temperature of the water through color variation.
Temperature below 30 degrees C, green water, cool water; from 32 to 40 degrees water turns blue, warm water. From 42 to 50 degrees water turns red, hot water. And when the red light blinks continuously, the water has risen to> 50 degrees, very hot warning.
The outstanding advantage of 360 degree nozzle makes it easy to clean the dishes even when the power is out. Your loved one may enjoy helping you wash dishes without worrying about burns.
In particular, 360-degree probes can be suitable for both sanitary faucets, hand washers, or washbasins in your family.
See more at: http://learncookingus.com/no-sprayer-with-my-faucet/
Re: Decklink Outputs Master Fader screens go white
Would you mind sharing your composition and the advanced output preset you use?
Also please send us the Resolume log file via the feedback tab in preferences.
