BeatLoopr disappears
Wiki
Post by Wiki »
Hi. I have problem with BeatLoopr.. Hi disappears in some clips when i work with resolume. Why? Everything is on in preferences, but sometimes BeatLoopr in clips disappears and i can't use it. :oops:
He2neg
Re: BeatLoopr disappears
Post by He2neg »
ist the transport of the clip in bpm ?
~Berlin~
Wiki
Post by Wiki »
Yes! In my home when i turn on resolume everything works. But when i use Resolume Live 2, 4, 6 hours some clips dsnt have BeatLoopr. It disappears... What am I doing wrong :?
Could you post some screenshots of the clip panel how it looks when the beatlooper is missing?
Wiki
Post by Wiki »
Now I can't post some screenshots because its broke in my last performance, after a few hours when resolume turn on. The panel with BeatLoopr disappeared (random clip). Now when I check this in my home, everything works ok, but i find something strange bug related with BPM.
Does this happen only for this file, and this composition or does it happen with a different file in a new composition also?
Wiki
Post by Wiki »
This happen for all new add files, but in new composition works fine... This composition and presets is all my life :) Can I fix it without changing composition and presets?
He2neg
Post by He2neg »
Do i get it right that the problem is:
" the default clip transport dont work correct and i have to set it for each clip manualy" ?
You can import whole decks into a new composition. Presets (effects ) , if saved, can be used in all compositions.
Maybe you have to do the work and it may help you.
~Berlin~
Wiki wrote: Thu Jan 17, 2019 04:03 This happen for all new add files, but in new composition works fine... This composition and presets is all my life :)
That's strange, could you send us this composition to mail@resolume.com?
I'm not sure if dragging the decks to a new composition would fix this, but doesn't cost anything to try ;)
Wiki
Post by Wiki »
When i try with a different compositions, layers, codecs, columns, decks there was still a problem. I used a default presets and compostition and this film simply show how strange and randomly is this problem. Unless I missed something. I send this composition to mail@resolume.com
