IR Clip SA or IR OSCSA - Effect Installation Issue
LKWalter
Post by LKWalter »
Hey Guys,
First, I use Avenue 6 on Mac OS High Sierra.
I have downloaded the plugins here: https://visution.com/legacy-products/stuff/
Now, i have tried to install these Effects several times. With no luck. I just can´t find them in the effect- list.
I followed all the instructions. Download, Copy Bundles in resolume>default>presets>Video Effect and also in documents. And yes, I added these folders in preferences>video>Plugin Directories
And I also activated OSC input.
I hope somebody got an advice for me.
Thanks a lot ahead!
Re: IR Clip SA or IR OSCSA - Effect Installation Issue
You'd need a 64bit version of the effect for Resolume 6, did you find one?
LKWalter
Post by LKWalter »
Ah ok, now I found this post with the same problem:
viewtopic.php?f=6&t=15488&p=73473#p73473
But I couldn´t find any mac 64 bit plugin for this. Just something like vezér, which is very complex again. Maybe its something they solve in the future. For now a little processing code helped me, I shared in the other post.
thanks.
AlexanderH
Post by AlexanderH »
LKWalter wrote: Thu Jan 17, 2019 12:15 For now a little processing code helped me, I shared in the other post.
Thanks for sharing the processing sketch! it works fine but i would love a mode for manipulating the transport speed with smpte not just the posiotion.. (like the + option in resolume) i´m afraid i can´t figure out how to update this funktion to your sketch... maybe you know a way? :D
