Audio Card disconnected from Resolume
pette
Post by pette »
in latest night, my external audio card had disconnected from Resolume Arena 6.1.1.
It is a usb Audio Card, I select it in the system preferences for audio output.
I start Resolume Arena, I selected the usb audio card from the menu and it work.
After 1 hour the Audio Card doesn't work.
I check in the Arena preferences and there was not my usb audio card in the audio combo box menu.
I check in my macbook preferences and the audio card was select.
So I quit Resolume Arena, I start again Resolume Arena, now in the preferences of Arena there is the usb audio card and it was no longer disconnected.
It is not the first time.
The other time, I reboot the Mac because I didn't check where there was the problem.
Re: Audio Card disconnected from Resolume
If Resolume detects that the Audio device is not responding or got removed, it will switch to a different device.
Could be a faulty USB connector or cable, have you tried with a different cable?
pette
Post by pette »
Hi Zoltan,
but the default system preferences at the same time detects it, and after the Resolume restart for about 4 hours I have no problem.
Maybe the cable has disconnected only for a few seconds and Resolume switch it?
pette wrote: Thu Jan 17, 2019 15:35 Maybe the cable has disconnected only for a few seconds and Resolume switch it?
That's what I'm thinking, yes.
