Control Settings - 1 Key Reset to Start position
pettypoh
Post by pettypoh »
I'm curious what's the best way to reset all controls to a "pre-set" default.
Example
- doing 3 of the exact same show sequence in 1 day. during each sequence, the controls (such as opacity, blend, clips) will be edited according to the show
- once one show sequence completes, what is a good way to do 1-key reset of all settings back to a "pre-set" to prepare for the next show?
- currently doing each settings manually via a checklist
Re: Control Settings - 1 Key Reset to Start position
Reopen the saved file
pettypoh
Post by pettypoh »
Oaktown wrote: Wed Jan 23, 2019 09:07 Reopen the saved file
thanks! but that would also "terminate connections" to the output screens, and audience knows there's a reset done
any other methods available?
Shamai
Post by Shamai »
what about duplicating the actual decks in the same composition before the first show, after the first show just go to the next deck and restart
You can reload the deck of the composition from the Composition panel. This should reset the clip properties and clip effects.
Alternatively you can create Keyboard shortcuts from the same keyboard key, to all the parameters you want to reset/set, With "This..." target and Value mode.
Then you san simply press this key, to reset all the mapped items at once.
