Microsoft Surface Book 2
James
Post by James »
Does anyone here use The Surface Book 2 to run Resolume 6?
If so, could you possibly give some feedback on it's performance?
I'm looking to replace my 2013 Macbook Pro Retina, as it can't keep up and causes Resolume to stutter, possibly due to cooling issues, or just generally being old.
I had originally decided on a Razer Blade Stealth 13 4K Touch, but they're out of stock. So my preference has swayed to the Surface Book 2.
Bare in mind, as well as Resolume and Ableton, I also do a lot of work with Premiere, Photoshop, Illustrator and Animate CC, so my purchase would have to suit all needs. So high screen resolution and touch are kind of compulsory.
James
Re: Microsoft Surface Book 2
Post by James »
Just for the record, in case any future users make the same request:
I've since bought a Surface Book 2 and can now provide the feedback I was seeking.
I can confidently say Resolume runs beautifully on it.
deflost
Post by deflost »
hello_
which version, avenue or arena?
maybe u can do a benchmark test for it?
thx.
r.h.
westfernsehen, leipzig
James
Post by James »
I'm using Avenue.
Happy to do a benchmark test.
What platform would you recommend I use to benchmark?
Here you get the ""official"" Resolume benchmark instructions ;-)
Resolume Benchmark
greetings
w10 || Schenker U506 || lemur || kp3 || pulse || leap motion || magewell capture dongle
