NDI Dropping out
paulglave
NDI Dropping out
Post by paulglave »
I have an NDI source from a windows laptop, connected into my 2015MBP. The Mac is receiving the NDI with no problems, but Resolume keeps losing it every 10-15 seconds. The laptop is connected directly via cat5e cable with no router or switch. The WIFI adapter on the Mac is switched off.
Re: NDI Dropping out
Try switching off all unused network devices also on the sender. restart the machine and try again.
If multiple network interfaces are active on the sender, the NDI server announces all addresses, and the library might try to connect to an ip that is not accessible between the machines.
