New Update broke something
James
Post by James »
A new update for Avenue just ran, and since then I have no longer been able to Export media as DXV from Premiere Pro CC.
Any ideas?
Online
Re: New Update broke something
At which point do you get stuck when you are trying to export DXV?
And which Adobe version are you using exactly?
https://resolume.com/support/en/dxv-exp ... be-cc-2018
James
Post by James »
Adobe Premiere Pro CC 2019
When going to Export>Media, then in Export Settings column, in the Format drop down, DXV 3 used to be in there.
Avenue ran an update when I opened it. Since the update DXV 3 is no longer an option on the above.
Online
​Try installing the Resolume update again, but this time make sure, all your Adobe programs are closed.
You can get the installer directly from our [link=http://resolume.com/download]download page[/url].
