Autopilot Column
PERCYJOSEPH
Autopilot Column
Post by PERCYJOSEPH »
I would love to see the option like Autopilot on Clips, lets have an Autopilot from Clips to Column Trigger. Like on a clip you can select what to do once it finish, there should be an option to trigger the selected column so that the duration on one clip can decided the full duration of that column.
Re: Autopilot Column
Moved to feature requests ;)
PERCYJOSEPH
Thank you
Yuckfou157
Post by Yuckfou157 »
+1 :D
moha20106
Post by moha20106 »
Zoltán wrote: Mon Feb 04, 2019 12:35 Moved to feature requests ;)
officialyourdad
Post by officialyourdad »
+1 Thank you
Grimm90
Post by Grimm90 »
waaaant
renemistergiant
Post by renemistergiant »
YES!!!!!! Please add this option:
And even better would be a key trigger(s)! That way you could program that something is done after a certain clip is played. Like "next deck"
PERCYJOSEPH
Always a +1 for any request on Column Trigger Options
Snoxxx
Post by Snoxxx »
+1 with Group column
