Does anyone know of a software solution that would be able to capture the artnet out from Resolume 6 running on the same machine, and convert it back to DMX for my 'ol trusty Enttecc usb dmx interface to send out ?
All this artnet stuff is great for whatever more complex stage or installation.
But if you just need to control 2 rgb spots & 2 strobes it's really a pain in the ass, i end up taking my mac with me with QLC+.
If this wouldn't work , whats the cheapest simplest working artnet node i can get atm ?
Don't mind soldering some stuff & making a box.
It's just for the couple of times i need to control a few dmx channels in a year , i don't want to spend 150$ at the moment and throw my enttec in the drawer.
						Artnet to DMX software
Re: Artnet to DMX software
Create a simple network in TouchDesigner that receives Artnet (DMX In CHOP) and outputs it via a USB interface (DMX Out CHOP)
so easy & before my nose that i just couldn't think of it .. Thanks Oaktown !
If i get it working i'll share the touch patch on the dev subforum.
You're welcome and it should be an easy one to create!
