can anyone send yours BCF2000 configuration file (XML on the resolume dir) and BCF2000 preset for resolume =?
or explain what commands do guys use with BCF2000 ?
[Edited on 20-8-2005 by Danger]
						BCF2000 configuration/help
				activstudios
BCF2000
[font=Tahoma]I have set up the BCF2000 to work with resolume, it works great but not a simple job.
First off you need to reprogram the BCF2000
(i can dump the sys file for you if you need, and you can upload it with the BCF2000 edit Application downloadable from the beringer support website) I can also send you my xml file from resolume if required. VJ ISISfont]
yes please send both files to danger@hiperbock.org
i already have one configuration to but i like to know how you people use BCF2000 out ther
The stange thing is that the faders work great, but i need some help on assigning the other functions... Does the behringer program work on your pc? Mine gives an error when trying to run that jar, the loading dialog apears but the whole thing hangs on it.
When you try to run the jar using commandline (java -jar [name].jar) it gives an error in the main function blabla
