waveforms and spectrums please!!!
sTuVIdR
Post by sTuVIdR »
Hi can we please get waveforms and spectrums to function as sources as Resolume? ie so that the audio input creates a waveform (on an alpha channel background) or creates a spectrum analysis (frequency range FFT etc).
These should be pretty easy to implement I would think, especially since the spectrums are already appearing as a mod option, etc.
Currently there are a couple of workarounds to make this happen:
ie using syphon/spout and routing out of another program (which is clumsy and can create a lag)
or using bigfug plugins which are rather flawed and bug-ridden
But a native waveform/ spectrum would be amazing!
Plus can we get a variable period etc on the waveform (the more variables the better actually for both these sources.
Thankyou!!!
officialyourdad
Re: waveforms and spectrums please!!!
Post by officialyourdad »
This feature would be so great and as mentioned I presume it would be easy to implement. Please do add +1
davesro34
Post by davesro34 »
this would be super convenient
FFT you can do with the Reveal Effect ;)
