Hi there! I'm new to resolume arena and I'm trying to understand if it's possible to map live cameras. I want to map 4 live cameras along with pre-recorded footage with smpte audio code. Is this possible? Can I map commands of start and stop with live cameras?
Thanks,
David
mapping live cameras
Online
- Team Resolume
Re: mapping live cameras
Yes, you can use live cameras in Resolume: https://resolume.com/support/en/live-inputs
You can set the camera clips to SMPTE and they will only display in the TC range the clip Offset ant the clip Duration specify.
You can launch the camera clips manually or map the clip launch to midi, keyboard, DMX or OSC Shortcuts.
