Custom osc values
SystemD
Custom osc values
Post by SystemD »
I'd like to send osc data from resolume to start some cues in a dmx software.
The idea is when i start a clip, resolume send an osc message to trigger my cue in the dmx software.
For each clip, resolume send 2 osc messages : 1 for the clip that stops and an other for the clip who starts.
But the arguments are integer 1 or 3, not 0 or 1.
If i move a slider with a custom osc adresse, the argument is a float between 0. and 1., so no problem.
Re: Custom osc values
When you set clip connect to a custom address, it actually sends the values for Connected state.
These values would be int 0-4
0: empty slot, you get this when you (re)move a clip
1: disconnected, not previewed
2: disconnected, previewed
3: connected, not previewed
4: connected, previewed
SystemD
Post by SystemD »
ok, thanks for your explanation Zoltan
