Hello
I would like to send 4 layers to 4 syphon-outputs so that the layers can be processed in another program in Mac. Is this possible? I only manage to get 1 syphon-output out of Resolume, the composition
:SOLVED: multiple syphon-outputs
mortenstensland
mortenstensland
Re: multiple syphon-outputs
I found the solution on the archive in this forum. it works in Arena.
In advanced output, create 4 screens with syphon output, and 1 slice each which covers the whole screen. Set the input for the slices to layer 1-4.
Now each layer has its own syphon-output. It seems to work well
