Alternative to fx4
willtom
Alternative to fx4
Post by willtom »
I'm looking at splitting a uhd hdmi output into four hd outputs on 3g sdi. An fx4-sdi is roughly £2200+vat, a fx4/h & 4x hdmi>sdi totals about £1700+vat, and a hdmi>12g sdi converter into a 12g>quadlink 3g split totals about £800+vat.
Are there any clear disadvantages to doing it the cheap way? Or in this particular set of circumstances are these all basically identical solutions?
(I know I'll lose the flexibility of non broadcast resolutions, and the 12g solution won't be expandable up to 7680x2160@30, but I can live with those two limitations)
He2neg
Re: Alternative to fx4
Post by He2neg »
if you just want to spilt a 4k hdmi Signal into 4 SDI 1080 outputs you can use
https://www.aja.com/products/mini-converters/ha5-4k
~Berlin~
willtom
Post by willtom »
He2neg wrote: Fri Mar 08, 2019 12:16 if you just want to spilt a 4k hdmi Signal into 4 SDI 1080 outputs you can use
Wonderful, thank you
lightbx
Post by lightbx »
Last thing to note is that the Fx4 keeps all frames in sync, and the AJA HA5-4K can be offset by about 1 frame, or ~50ms. Another user ran a test and provided these numbers here, I believe in a thread specifically about the HA5-4K.
If they are all separate screens, and especially if they are all playing different content, the AJA will do what you need just fine (and at a third of the price). If you plant to edge blend 4 1080p signals together, or array 4 screens into a single image somehow, you'll want to keep your frames in sync.
willtom
Post by willtom »
There is a chance of this being use for edge blending. I'm surprised to hear that quadlink sdi isn't kept in sync, do you have a link for the previous discussion?
kman1898
Post by kman1898 »
lightbx wrote: Tue Mar 12, 2019 04:05 Last thing to note is that the Fx4 keeps all frames in sync, and the AJA HA5-4K can be offset by about 1 frame, or ~50ms. Another user ran a test and provided these numbers here, I believe in a thread specifically about the HA5-4K.
From what I’m reading in that post the frames are in sync. The delay is from computer to the ha5 itself. There is a similar 1ms delay with the fx4
SiNiSon
Post by SiNiSon »
Anyone know how the aja handles HDCP most vid cards and laptops spit out HDCP on the HDMI.
lightbx
Post by lightbx »
I've had no issue with a 2016 Macbook Pro HDMI out. Going to test later this week with a 2019 MBP using a 4K60 cable (Thunderbolt 3 to HDMI).
kman1898
Post by kman1898 »
SiNiSon wrote: Sat Dec 07, 2019 20:14 Anyone know how the aja handles HDCP most vid cards and laptops spit out HDCP on the HDMI.
I’ve had zero issues with my ha5
the FX4 has more options for configuration and raster manipulation. You also get to lock the clocks on your outputs to a single source and you can expand the fx4 to other units to have that same clock source drive those outputs. those features make me not want to recommend anything else.
If you don't care about screen tearing then go other routes, if you care about the quality of your product, the fx4 is hands down the way you want to go.
