OUTPUT DISPLAY 2 NOT FUNCTIONING
fer
Post by fer »
My computer is asus scar 2 and disable Sonic Suite II and still present the same failure
I've got resolume arena 6.1.2 running on windows 10 with following config
NVIDIA GEFORCE rtx 2070
core i7-8750H CPU @ 2.20GHz 2.21 GHZ
16 RAM
DirectX 12
when I connect the second display via HDMI and set output to second screen , resolume CRASHES and starts NOT_RESPONDING
PLZ HELP
THANKS
Re: OUTPUT DISPLAY 2 NOT FUNCTIONING
Any other Asus related pre-installed programs on your machine?
Do you have Asus GPU tweak, or Afterburner running?
Libinmathew7
Post by Libinmathew7 »
what i have done is i went to display configuration/surround spanning option then physx setting i change to rtx 2070 before that i reset my pc fully...and uninstall sonic software also ..my pcs starting working nicely....i got 5 system with same issue ...now all of them are are working fine /......try this buddy :P :P :P :P :P
