would be great if there was a 'Black BG' checkbox into the transform effect
works the way you want it to when applied to a clip or to composition/layer, but I usually put my effects in stacks in clips, haven't found a blending mode that works the same
anyone got a work around?
transform effect
Re: transform effect
Did you try the 'Cut' blend mode?
