FPS question
ld8807
FPS question
Post by ld8807 »
Hi guys!
I’m wondering if it’s a good result/normal FPS.
I’m running 3 clip/3 layers1920x1080 30 FPS DXV3 .
I’m outputting on 2 external screen 1920 x 1080..
And the FPS in resolume varies between 55-58..
If I run 3 clips 4K dxv3 .. 30 FPS..
I get something between 50-52
Is that bad? Good? Ok?
(Gtx 1060 max q... up to date)
Re: FPS question
If you're interested in raw performance comparison, check out the benchmark thread here: viewtopic.php?f=11&t=11093
If you want to find out if it's enough for what you want to do, some details about what you want to do would help ;)
