Video fader doesn't work on advance output
PERCYJOSEPH
Post by PERCYJOSEPH »
Composition video fader doesn't fade all the videos in the advanced output mode. please check. The master fader is working but it fades the audio too at times we just need to fade all the videos a little if the brightness is high and i believe it was working earlier.
Re: Video fader doesn't work on advance output
PERCYJOSEPH wrote: Sat Mar 23, 2019 07:11 Composition video fader doesn't fade all the videos in the advanced output mode. please check.
Do you have slices routed from layers in the advanced output?
PERCYJOSEPH wrote:The master fader is working but it fades the audio too at times we just need to fade all the videos a little if the brightness is high and i believe it was working earlier.
Well, it's called Master.
There is a separate video opacity fader in the composition panel, if you only want to dim the output.
PERCYJOSEPH
"Well, it's called Master.
There is a separate video opacity fader in the composition panel, if you only want to dim the output."
it is this video opacity fader that is not working when you output through advance output.
There is a master fader. It fades out everything that goes out of Resolume. The composition video. The composition audio. DMX output. Layer video that is routed to slices. Everything.
There is a composition video fader. It only fades out the composition video. It does not fade layer video that is routed to slices.
Keep in mind that by routing a layer to a slice, you actively decide to bypass the composition completely.
From https://resolume.com/support/en/slice-r ... ce-routing
