dmx - midi shortcuts
koenmaes
Post by koenmaes »
I run Resolume 6 and made for a project a DMX mapping. Works great! ;)
Now I want to make another project/composition and use a dedicated MIDI mapping.
However I chose a new composition (project), the old DMX mapping still shows up and I cannot map my midi device.
I don't want to lose the old DMX mapping - thought it would be saved in the composition file.
Anyone with good advice to help me out?
Thanks a lot!
Cheers,
Koen
Re: dmx - midi shortcuts
Shortcut presets are saved in a separate folder, in Documents/Resolume Arena 6/Shortcuts/
The composition only stores which preset you had active when you last saved the composition, so Resolume will load those presets for you.
DMX and Midi shortcut maps are two separate things.
You can have both assigned to a composition, changing a midi mapping won't affect the active DMX mapping.
https://resolume.com/support/en/dmx-shortcuts
https://resolume.com/support/en/midi-shortcuts
