After Effects: Exporting on High Quality changes colours
hasher22
Post by hasher22 »
Hello,
My composition in After Effects is nearly all yellow, when I export with settings, DXV 3, High Quality or High Quality + Alpha, the final outcome is a video with the yellow being pink.
BUT when I export to normal quality or normal quality + alpha, the colours are correct.
How come the "High Quality" setting is making my project different colours?
I would like to export on high quality + alpha not normal quality + alpha.
dirtyjohn_lv
Re: After Effects: Exporting on High Quality changes colours
Post by dirtyjohn_lv »
This kind of goes along with my question as to why some HQ files are also smaller?
Simple 4K@30fps composition, 1 minute in length with SMPTE color bars, the Normal file is much larger than the HQ file
https://app.box.com/s/b5pa9enni3slgjvbghllgrkta65lywk7
Which After effects version are you using that outputs the wrong colors to DXV?
hasher22
Post by hasher22 »
Zoltán wrote: Fri Apr 26, 2019 09:00 Which After effects version are you using that outputs the wrong colors to DXV?
16.1.1 build 4
dirtyjohn_lv wrote: Thu Apr 25, 2019 18:09 This kind of goes along with my question as to why some HQ files are also smaller?
DXV3HQ uses a different color space. Instead of storing the colors as RGB values, it stores them as YUV.
hasher22 wrote: Fri Apr 26, 2019 10:24
16.1.1 build 4
I can't get it to break on my windows machine,
could you try exiting all Adobe products, installing the latest Alley from our download page, and rendering to DXV HQ again?
