Hi all!
I'm about to operate a BIG show on a two PC desktops in parallel using OSC control (for backup reasons),
#1 specs:
Asus Prime X299 LGA2066 motherboard
i9-9820x
32gb ram
Samsung 970 pro nvme
RTX 2080
Blackmagic decklink 8k Pro
Resolume arena 6.1.3
#2 specs:
Asus rog z-370g motherboard
i7 8700k
32gb ram
GTX 1080
Blackmagic decklink Duo 2
Output pixels can be mapped into three 4k outputs and one 1080 Output - and of course i need a UI screen... total of 5 screens.
Three 4k led wall controllers and one projector.
My questions are:
The maximum GPU's (RTX 2080 and GTX 1080) output resolution is 7680x4320@60Hz and only 4 outputs at the same time -
If i use the Motherboard output OR Blackmagic SDI output. will it considered as a GPU resolution output or not?
can i use this output as a UI screen or UI must be on main GPU?
Thanks.
Daniel.
Big scale RIG.
Re: Big scale RIG.
I would send 5760x2160 through two FX4's if your going into an E2. That way you can fit on four outputs.
Do you know what your plugging into? Image pros? E2? spyder? Ascender? Vio 4K?
That really helps in what people can suggest besides just buying another video card.
Re: Big scale RIG.
Any news on this topic?? Im looking for a similar setup and this could be useful.
The only thing i can tell you about your questions, is that i dont think is possible to use the motherboard output at the same time that the Gpu.
I think having 2 gpus is the only option to that many outputs
- Bassindaniel
Re: Big scale RIG.
Worked flawless
GPU 60% at 65 Celsius
CPU 30% on 45 Celsius
GTX 1080
DP_1 2160p
DP_2 2160p
DP_3 2160p
HDMI 1080p
BM_1 sdi out 1080p
BM_2 sdi in 1080p
BM_3 sdi in 1080p
GTX 1080
DP_1 2160p
DP_2 2160p
DP_3 2160p
HDMI 1080p
BM_1 sdi out 1080p
BM_2 sdi in 1080p
BM_3 sdi in 1080p
