Sending color info with some console or Dashlight
Marijano
Post by Marijano »
Hey VeeJays,
I want to send color information or something triggering a scene(I mean complementary color with the clip) on console or dashlight. In example if my clip is red I would like when it is played my fixtures(beams i.e.) to get red or other gropus something different based on every clip I have. Is there possibility to do this somehow?
Also if possible when I trigger certain clips(if possible) they could trigger special scenes[flash scenes].
I would like to control lights with dash + MIDI and visuals with different MIDI controller and laptop but I want colors to be "hardcoded" and then if I need to I will change it...
Thank you !
Re: Sending color info with some console or Dashlight
Would you like to control Resolume with info from an external source, or would you like to control your external device from Resolume?
