Airbeam
newbie
Airbeam
Post by newbie »
Hey guys ,
for some reason i can't find the AirBeam pro app in the sources of Arena 6
Any ideas
Thank you for the help
cheers
Re: Airbeam
I'm sorry, Air Beam is not supported as Input.
You can use Syphon (Spout), NDI, or a capture source to get external video into Resolume:
https://resolume.com/support/en/live-inputs
https://resolume.com/support/en/syphonspout
Scratchpole
Re: Airbeam
Post by Scratchpole »
The Airbeam app on your computer outputs a Syphon stream when you click on your input and it opens a live view window of your device. It will then become available in your sources list.
