Desktop or Laptop?
Nixzero
Desktop or Laptop?
Post by Nixzero »
I've played with others' Resolume setups and want a nice rig to work with on my own. Every setup I've seen has used a laptop, but I have some VR projects planned (namely Microdose VR) that may be too demanding for the laptops in my budget ($2000 for the computer and projector).
Is it practical to VJ using a desktop? If not, are there any laptops in the $1500 range that would be up to snuff? I don't mind buying used/refurbished.
Re: Desktop or Laptop?
Hey Nixzero,
just booted up with a coffee and saw your post.
There are several refurbished and/or used highspec notebooks on ebay for 1500 and less.
Just search for Notebooks with a 1080ti. Keep one eye on the video outputs. you want as much as possible.
And the other eye on a present m2 ssd or the possibility to add one. That's it. ;)
Happy shopping
p.s.:
It can be practical to use a desktop if you would like to add pcie capture cards, more videocards for more outputs and so on.
Digitrevx
Post by Digitrevx »
If you are up for a hybrid that is mobile enough there are SFF desktops. It's a little more hassle then a laptop since you need to travel with a monitor. I use viewsonic 21" touch screens that fold to 1 inch thick.
I use this machine currently. More IO and usb controllers then a laptop. Weighs about 15lbs. I couldn't imagine flying on airplanes with anything much bigger.
Grimm90
Post by Grimm90 »
that looks so nice , but hows your cooling ?
401niz
Post by 401niz »
Digitrevx wrote: Fri May 17, 2019 18:55 If you are up for a hybrid that is mobile enough there are SFF desktops. It's a little more hassle then a laptop since you need to travel with a monitor. I use viewsonic 21" touch screens that fold to 1 inch thick.
Any chance you would be willing to share that build? Your rig looks good. I’m in the process of spec’ing out my first dedicated machine and really like that case/form factor
