Second Window Split layout!?
pistalgeek
Post by pistalgeek »
Correct me if im wrong, but you cant Split the layout into a second monitor right? I just had a thought about splitting all touch faders and knobs on a bottom touch screen, then a play head, output, etc on the top screen. Can we have that as a new feature??
Re: Second Window Split layout!?
Splitting up the UI to multiple windows is not possible currently.
What you could do though would be extending the Resolume main window to your other monitors, by resizing it to span over the other displays.
Using a Triple Head would be another solution to run 3 displays as one.
