dmx preferences
raybuay@hotmail.com
dmx preferences
Post by raybuay@hotmail.com »
hello
I do not know why the new input button at the dmx preferences settings
only allows me to create 4 universes. after universe 3, the button goes grey
and i cannot create anymore. how can i fix this please
cheers
r.y
Re: dmx preferences
Resolume supports 4 Input universes currently.
That's 2048 individual control channels.
Do you need more?
Re: dmx preferences
raybuay@hotmail.com, I'm assuming you want to create DMX universes for output not input, correct? If that's the case, you need create the Lumiverses in the advanced output not in the preference menu.
https://resolume.com/support/en/dmx
raybuay@hotmail.com
Re: dmx preferences
yeah, i got confuse with that. i do not really need any dmx inputs. only
outputs. thanks, r.y
by the way, does anybody know if it is possible to increase
the 115200 baud rate. i know that that is the dmx standard
but when you are running led strips, it can get a bit slow and
have many drop frames.
glediator has an arduino sketch that runs at megabit rates.
is it possible to use artnet at those rates or is there a limitation
that doesn't allow this?
cheers
r.y
