Switch Resolume Arena License 2 laptop
pette
Post by pette »
I have a old MacBook Pro 2014 and I want to buy a new laptop, so an
"ASUS Notebook Rog Zephyrus S GX531GX-ES002T"
I think is good for Resolume.
So if I use the new laptop can I switch the license I have in MacBook Pro?
So if in the future I want to have a backup laptop is easy to switch the license between one other?
thanks
Re: Switch Resolume Arena License 2 laptop
The licenses can be moved to new machines any time with a working internet connection.
You can do the transfer yourself very easily.
Just connect your machine to the Internet and open Resolume Preferences.
Select the Registration tab.
To unregister press the unregister button, and on the new machine in the same tab
enter your serial to register and click register button.
You can find our article describing the process more in depth here:https://resolume.com/support/en/registering
pette
Post by pette »
So it is really fast!
Yes, it's just a few clicks.
blipson
Post by blipson »
Zoltán wrote: Tue Jul 02, 2019 07:18 The licenses can be moved to new machines any time with a working internet connection.
This link is dead. Can you update the link to this info?
blipson wrote: Tue Aug 13, 2019 08:24
done ;)
