Best and compatible Switch for NDI
moha20106
Post by moha20106 »
Hi all,
For people who using NDI for capturing screen
What is the best and compatible Switch for non delaying/latency to use?
Is it Managed or Unmanaged?
What about the buffer memory, is it important or not?
All i need is capture screen from 3-4 laptops
Without delaying
Thank you
Re: Best and compatible Switch for NDI
moha20106
Post by moha20106 »
Zoltán wrote: Sat Jun 29, 2019 12:15 This could help:
https://forums.newtek.com/attachment.ph ... 1527693707
Dear Zoltán, thank you very much for your support
No problem! ;)
