When I use line generator and select the quantity of lines to be 1, it produces 2. Help please!
LongJessi
Post by LongJessi »
I am using the line generator to create a single vertical line that goes back and forth, but for some reason it keeps putting 2 lines instead of just 1 :evil:
Re: When I use line generator and select the quantity of lines to be 1, it produces 2. Help please!
Amount specifies the number of lines that should fit into the Height of the clip.
Try zooming in to the clip if you'd like display a single vertical line.
