APC 40 mk 1 template in Resolume 7
borez
Post by borez »
Hi all, I just bought Resolume 7 and want to use it with my original APC 40 MK1, I see a Mk2 template but not one for a Mk1. Does this exist anywhere and if so were can I find it?
I haven't tried it yet as I'm away from my studio, but perhaps the mk2 template also works with the mk1?
Re: APC 40 mk 1 template in Resolume 7
There are only a few factory midi presets shipping with Resolume.
They can give you a general idea of what's possible, but we recommend that you create your own shortcut presets which then will fit your workflow exactly.
You can read more about how to do that here: https://resolume.com/support/en/midi-shortcuts
borez
Post by borez »
No worries, I finally made my own template, took me about half an hour. Very quick process.
powertoaster
Post by powertoaster »
Hi @borez, mind sharing your Mk1 preset?
theLABVisuals
Post by theLABVisuals »
I may have another play with this and update it ...
https://vimeo.com/43073087
powertoaster
theLABVisuals wrote: Fri Oct 02, 2020 21:58 I may have another play with this and update it ...
please let me know if you do! I was all excited to use the APC MK1 until I started reading about how difficult led feedback is.
