Demon stagelinq
wimpy
Demon stagelinq
Post by wimpy »
Is there a way to automatically link video clips to music files by filename or something?
If not it would be a great option. Like pointing to a folder of music files and if the clip matches the filename it can automatically link instead of manuelly having to drag the track to the clip from the denon stagelinq player.
I know it only needs to be manually linked once, but if adding 10+ each gig it world be handy..
Re: Demon stagelinq
If you name the video clips the same as your tracks, load the video clips into Resolume, select all, and in the clip menu, select Transport - Denon.
Now all clips should be linked to the same tracks that are the same name as the clips.
