FFT Input
cvanhoose
FFT Input
Post by cvanhoose »
Whats up with the FFT input?
Download one of my Generative sets here: http://cvhvisuals.com/footageshop.html
Compare it in both R6 and R7.
Cant seem to make an effect dynamic anymore. Although the audio analysis in the FFT window looks more dynamic.
Example: basic EQ effect using Reveal effect and audio Input. You can load a clip in the generative set and will see a flat EQ in R7 as to R6 produces a dynamic EQ.
I have tried to re-add the effects and audio links with the same result.
Also the input level is a difference between the two versions. R7 need to be cranked up to max to reach the same level.
Maybe this is an issue with the reveal effect?
Re: FFT Input
Looks like the input in 7 is 6 dB lower for some reason.
Do you also see a difference in the frequency response?
