Weird lines in slices setup
Frischvergiftung
Post by Frischvergiftung »
Are these new double-lines around slices a bug or a feature? I am not sure what to make of them.
Cheers, Max
https://imgur.com/a/C8WZ9Di
Re: Weird lines in slices setup
Looks like a bug.
Could you send us this screen setup preset,
and the Resolume log file via the feedback tab in preferences?
Frischvergiftung
Hm, i can`t recreate the problem now... perfect :) Problem solved.
Will keep an eye on this and post here if it returns! Thanks!
Did you see this in Resolume 6 or 7?
Menno
Post by Menno »
I've recently noticed this issue as well and it is definitely a bug. I've been looking into it and already solved 1 outline being off by 1 but there's more outline issues i didn't find yet, will keep looking and fix when i find it :)
