Black Out
Locked
cat
Black Out
Post by cat »
Been doing some band gig's and quite often need an everything off at once button, is there one?
If not a bypass all layers button assignement would be good
cheers
Cat
to make everything black (or any other colour) at once you could have a black picture in your deck and insert that in the top layer as soon as you need to go black.
Danger
Post by Danger »
nice turn around bart :)
edwin
Post by edwin »
Well bart's solution is not completely flawless.
What if you top layer i set to a let's say 50% opacity.
Then you would still see the layers beneath.
Another solution is this, assign a note to the Treshhold effect. And set it's value to a default of 255 (set it to 255 and press the floppy disk button). This way everything should go black when you trigger the effect.
And triggered again (toggles on/off) everything will be visible again without losing settings of the layers.
Cheers
Edwin
Danger
Post by Danger »
edwin: thats even a better turn around :)
JCASTLD
Re: Black Out
Post by JCASTLD »
Hi there,
What is the floppy disk button you speak of lol? I can only get piano mode flash button to work but not a "toggle" in Normal mode. Also, when I do this I can only get it to black out 1 layer, how do i get the blackout to assign to all layers? Thank you
Re: Black Out
This thread is from 2005 :) I suggest to start a new thread and explain what you want to do there.
Locked
