MacBook Pro / 4 outputs?
westframe
Post by westframe »
Hi Resolume community.
Maybe a simple question, but what's the most reliable solution to OUTPUT Resolume to 3 projectors (max 1920x1080 times 3) from a MacBook Pro with 4x USB-C ports? Any HDMI-hubs/adaptors to recommend? Are there adaptors to output 3x DisplayPort / HDMI using only 1 USB-C port?
AND is it possible to output a 4th screen (to HDMI /or SDI): the preview window from Resolume? So I can communicate the "next clip coming" to another room with monitor.
Would be most appreciated to get some solid experienced answers. Merci !
Scratchpole
Re: MacBook Pro / 4 outputs?
Post by Scratchpole »
Datapath Fx4.
Use the fourth quadrant of your output as your preview for control room.
