Resolume 7.0.2: Dongles are taking over
This update fixes an issue, where using a Dongle, the watermark can still appear after 30 days.
#13151 Dongle registration can show watermark after 30 days
We also fixed these other issues:
#13081 Resolume freezes connecting two Launch Pad Pro-s
#13093 OSC int commands no worky for 2 state buttons and checkboxes
#13105 Slice Bypass/solo is ignored if a Video router is playing in the layer.
#12975 Alley's conversion count is off
#12145 Pre-select width, height numbers in Alley conversion settings, when entering the
#13096 Auto pilot with clip on bounce doesn't fire properly
#13080 OSC: /composition/crossfader/phase no worky to control crossfader
#13125 Reveal effect external audio seed - audio analysis broken
#13102 DropShadow Distance param behaves weird
#12897 Slice transform slice bypass stops working in mask mode when toggling half of the sliceswith the same shortcut
#12917 Make Alley do a multiselect when dragging in a folder
#12631 Stripping illegal characters can result in hidden files
#13038 Prores file synced to Denon and SMPTE plays choppy on mac
#13154 Crash on startup with missing midi shortcut target, and controller plugged in
Click on "Check for Updates" in the Avenue or Arena menu and it will update itself or download here.
Grimm90
Re: Resolume 7.0.2: Dongles are taking over
Post by Grimm90 »
Yay , more fixes !
Has anyone of the dev team had a moment to look at the Goo & Recolour FX ?
Last time i tried , recolour is still recolouring alpha into solid.
Goo , with super subtle settings , is going to a max state when triggered as an FX clip , and then levels out at chosen settings :/
Grimm90 wrote: Sun Aug 04, 2019 09:38 Yay , more fixes !
Have you seen the Use Alpha button in the Recolour effect?
Goo should also work nicely in 7.
