Can't order decks
borez
Can't order decks
Post by borez »
Ok, I'm having issue with ordering my decks, Resolume won't allow me to to drag and drop a deck from the middle of the pack of decks to the end, it just places it either one or two spaces back.
Anyone have any ideas, is this a bug?
Re: Can't order decks
Which Resolume version are you using?
borez
Post by borez »
I'm using Avenue 7.0.2
I managed to get the decks in the right order eventually but it was purely by chance after a lot of dragging and dropping.
When you drag your deck, and move it above your deck buttons, you should see a drop target appear in the form of a green line between the deck buttons. When you see that and release your deck, it should be dropped to the exact spot.
We've been able to recreate this, and made a ticket.
